Go Back   Toyota CelicaSupra Forums > Tech Talk > Engine / Intake / Exhaust
Reply
Thread Tools Display Modes
  #31
Old 03-19-2006, 06:29 PM
StanS StanS is offline
CelicaSupra.com Member
Jen
The machining is beautiful. How did you make the bellmouth's? The power gain that you're getting is from effectively increasing the tp area by a factor of 6 if your using the same size tp as stock. Even doubling the tp area from stock should give you a good gain. The length of the tubes should be increased if you want max power for two reasons. First with such short tubes the resonances (that induce extra air into the cylinder as the intake valve starts to open) will probably start at too high an RPM. Secondly, and probably more importantly, the VE is the highest when you have a longer column of air. When the intake valve opens the air in the column (tube) starts to accelerate and fill the cylinder. Somewhere in the middle of the stroke the column air reaches maximum velocity. Near the end of the stroke the piston is slowing down to a crawl while the air column has momentum which keeps filling the cylinder, thus raising the charge pressure (and mass) in the cylinder. A short air column has less momentum and will fill the cylinder less. If your going to run at the stock RPM range then the tubes should be about as long as the stock intake manifold (runners). Since your putting so much effort in (and doing such beautiful work) I suggest that you start
with a better theoretical underpinning (i.e. longer tubes). Good luck on whatever you do.
__________________
84 mt 6mge with intake, exhaust, suspension, brake, and wheel mods
85 mt 6mge stock
  #32
Old 03-19-2006, 08:50 PM
Dave A.'s Avatar
Dave A. Dave A. is offline
The Thinker
Send a message via AIM to Dave A.
Keep up the excellent work, Jen! Depending on what cams and valve timing you're planning to dial in, those ITB's should howl at the moon with relative ease. The air horn length combined with the port length should achieve some good airflow velocity as long as the diameter of the throttle plates are approx. the same as the port diameter. There's a whole slew of 4AGE engines running ITB's that are making plenty of HP with essentially the same type of setup as yours.
What static CR are you shooting for?
  #33
Old 03-26-2006, 10:31 AM
Jens Lyn Jens Lyn is offline
Tjeck This Out! :-)
Now the project is a little bit closer to the finish line than before :-)!
All the ITB are now ready for mount on the flange!
And i think it looks pretty nice :-)!
Here is an pic update!
Upload Images With PicTiger
More pic will come next week!
See ya
__________________
Home made 6M-JEP engine! 200+hp
No trys....No results!
  #34
Old 03-26-2006, 11:07 AM
ViPeR_NiPPleX's Avatar
ViPeR_NiPPleX ViPeR_NiPPleX is offline
Member
thats awesome, with a capital OMFG!
just makes me want to do all that to my 5m-ge
  #35
Old 03-26-2006, 03:57 PM
NashMan NashMan is offline
nice
__________________
Mk3 + Mk2 = MK5
Mk3 pa pa pa pa power maker 600 plus will be mine
Mk2 rooster tail maker aka rally car
  #36
Old 03-26-2006, 10:05 PM
Dave A.'s Avatar
The Thinker
Very nice!!
  #37
Old 03-27-2006, 12:10 AM
Tire Shredder's Avatar
Tire Shredder Tire Shredder is offline
24 Valves > 12
Send a message via AIM to Tire Shredder Send a message via MSN to Tire Shredder
oh my god that's amazing jen! we're all awaiting your results anxiously! so much talk it's good to see somebody able to do what they have planned.
I want some for a 7mge!
__________________
Black 7M-GE 84 P-type Hardtop
  #38
Old 03-31-2006, 04:11 PM
More pic of my project!
Here is the latest pic of my project.....I like it :-)
Host Image with PicTiger
Kind regards jens pedersen!
__________________
  #39
Old 03-31-2006, 05:05 PM
Solo1Supra's Avatar
Solo1Supra Solo1Supra is offline
Awesome work Jens.
__________________
Joe B.
84 P-Type
85 P-Type, Resurrection by Russ
87 Turbo
  #40
Old 03-31-2006, 09:18 PM
rsdeo's Avatar
rsdeo rsdeo is offline
Supra since '86
Great work. Please keep us posted with many pics.
One of the reasons I wanted a small machine shop in the garage... laithe, milling machine, plainer, etc.
__________________
OPEN SOURCE SOFTWARE It's free, easy to use and powerful
http://www.opensourcewindows.org/
Reply
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Sponsors
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
